Uus automakk (USB, AUX, SD)
hind 25 euri
Description:
Car Radio Stereo Audio MP3 Player 12V In-dash Single 1 Din FM Receiver Aux Receiver USB SD Remote Control
Features:
Supports advanced audio distribution profile
Off time display function
Digital high-quality FM stereo radio
Preset 18 stations ( frequency: 87.5-108 MHz )
Support USB / SD / MMC card reader
Support Audio: MP3 / WMA / APE / FLAC / WAV etc.
Support folder function
Support breakpoints and ID3 Play
Support remote control
Rotary volume control
MP3 randomized, 10 track up / down playback
Electronic control volume treble, bass, balance and fader
Multiple EQ scene selection: Jazz, rock, pop, classical, etc.
Mute and loud control
L / R RCA audio output jacks
4-channel high power output ( 4 loud speaker )
Support modes: BT / APE / WAV / WMA / MP3 / FM
The remote control battery ( included ): CR2025 3V
Specifications:
FM Radio
Tuning Range: 87.5 - 108.0MHz
Sensitivity: Less than 20db
Stereo Separation: More than 25db
SNR: More than 60db
Some Playback
Music format support: MP3 / WMA
Display format: ID3 display
Distortion: Less than 0.3 percents
Power Supply
12V Machine: 11 - 16V
Audio
Operating temperature: -20 - 60 deg.C
Quiescent current speaker impedance: 4 ohm
Frequency Response: 20 - 20000Hz
Fuse
Red: 1A
Yellow: 15A
Type: Car MP3 Player
Output Power: 4 x 60W
Voltage: 12V
Music Source: 3.5mm stereo headphone jack,Cellphone,Flash drive,SD
card
Built-in EQ: Classic,Jazz,Pops,Rock
SNR (dB): ≥60db
Degree of Distortion (%): ≤0.3%
FM Channel: 87.5 - 108.0MHz
Media Format: MP3,WAV,WMA
Array
Package weight: 0.642 kg
Product size (L x W x H): Approx.18.30 x 13.30 x 5.80 cm / 7.20 x 5.24 x 2.28 inches
Package size (L x W x H): Approx.22.00 x 18.50 x 8.00 cm / 8.66 x 7.28 x 3.15 inches
Note:
This machine is 12V machine, not according to the 24V power supply
Included:
1 X FM Radio Receiver
1 X Remote Control
1 X Wire
1 X User Manual
asub Tallinnas
ühendust saab PS teel tel 56791733
M: Automakk (USB, SD, AUX)
Kuulutuse sisestamisel mõelge hoolikalt läbi, et teist ei jääks halba muljet. Moderaatoritel on õigus oma suva järgi teie postitusi siit eemaldada!
